When I rotate a 2x4 ceiling grid, why does it rotate the ceiling lights too?
JL-Comdec
JL-Comdec
So, I select a grid line, click rotate, select a base point, rotate it 90 degrees. It works just fine for the grid... but unfortunately it is using that base point and rotating all lights, diffusers, and anything else attached to the ceiling 90 degrees as well. WHY? What setting can I change to prevent this?
ReActionCAD
Because they are hosted to ceiling. You can try using the disjoin function to break the hosting.
pkomatlapalli
Hi @JL-Comdec ,
We would like to follow up on this issue. Did the Disjoin option help in your case, if yes please click ReActionCAD solution as "Accepted solution".
If you're still experiencing the problem, please let us know, and we'll be happy to assist further.
Thank you!
Pavan Kumar | Community Manager
