when i double-clicked to launch revit 2019 , happens nothing
4 ANTWORTEN 4
Nachricht 1 von 5
266 Aufrufe, 4 Antworten
i have this problem since i installed revit 2019 student version . can anyone help me about that ?
4 ANTWORTEN 4
Nachricht 2 von 5
Avaris.
als Antwort auf: Anonymous
That could be anything, can you give us more information: Which Windows version? Do you have earlier versions that do work? Have you used Revit 2019 before?
Nachricht 3 von 5
als Antwort auf: Avaris.
i use win 8.1 . i have revit 2016 at the same time but it works correctly . i have't use revit 2019 before . the installation was good everything was good about it but i didn't understand why that is .
Nachricht 4 von 5
Corsten.Au
create a new shortcut to launch...
Corsten
Building Designer
Nachricht 5 von 5
Matt__W
I had a similar issue a few days ago. A clean uninstall/reinstall of Revit 2019 fixed the issue for me. I also have 2015-2019 installed. The issue popped up after I uninstalled 2014.
UNINSTALL REVIT
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/CloudHelp/cloudhelp/2018/...
Matt Wunch
Revit Subject Matter Expert/sUAS Pilot
Twitter | LinkedIn
AU2017 - Code Blue Dr Revit - How to Resuscitate Corrupt Revit Models
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button.
