When exporting family types revit uses wrong delimiter leading to loading errror
1 ANTWORT 1
Nachricht 1 von 2
199 Aufrufe, 1 Antwort
Hi everyone,
I'm trying to load a family with an associated type catalogue but its not working. Its showing that the .txt file is using a wrong delimiter and it can't be read, although the type catalogue was before exported by revit itself after creating the types. This means revit has used the wrong format when exporting. Now I can change it to the right delimiter by hand, but is there a way to make sure revit uses the right delimiter already when exporting the type catalogue? (Its using a dot . instead of a commma , )
Thanks for your help!
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: Anonymous
What do you by "exporting" the Type Catalog?
