When changing width of window it also changes height - how do I make this stop?
5 ANTWORTEN 5
Nachricht 1 von 6
asuttonR7BRT
380 Aufrufe, 5 Antworten
I am trying to have a 2'-6" W. and 8'-0" H. window but when imputing the dims. I want it automatically changes to a different dim. I am using an arched window and tried to edit the family but i'm unsure how to even work around that aspect.
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: asuttonR7BRT
Not sure I understand what you mean by "how to...stop".  Sounds like you might need a formula though.
Revit Formulas for "everyday" usage - Revit Forum
....actually, sounds like Height and Width are being driven by the same Parameter. If so, separate them.
Nachricht 3 von 6
There maybe a formula in the family that link the width and height.  Share the family here.
Nachricht 4 von 6
asuttonR7BRT
als Antwort auf: ToanDN
Thank you for your help - I have attached the family below
Nachricht 5 von 6
try this one attached herein.
Nachricht 6 von 6
What I did was remove the formula for Height from both the Host/Parent and Nested Family.  Also associated the Nested Family's Height Parameter to the Height Parameter in Host/Parent Family upon reloading.
