Wheel mouse does not perform pan functions in Revit 2018
45 REPLIES 45
Message 1 of 46
Darragh98
31302 Views, 45 Replies
Darragh98
This only happened to me in the last 2 hours and can't find a solution.
The wheel on my Logitech M305 Wireless mouse won't let me pan in the 3D mode, all I'm getting when I press the shift button to pan with the mouse is a minus sign above the cursor. I tried uninstalling/reinstalling the mouse and nothing changed. Went and got a mouse which is a plug in one with a wheel as well and that won't pan either. Revit really is getiing on my **** lately, has anyone got any sort of an inkling as to what could be causing this?
I'm in Revit Architecture 2018
Windows 8
Any bit of info will be eternally grateful. Thanks in advance,
Tomas
Windows 8
Tomas
45 REPLIES 45
Message 41 of 46
Viveka_CD
in reply to: Darragh98
Viveka_CD
Autodesk Support
Autodesk Support
Hi there @Darragh98
Thanks for the follow-up! Glad to know your brother helped resolve your issue. Kudos to him!
Hi there @Darragh98
Message 42 of 46
Darragh98
in reply to: Viveka_CD
Darragh98
Ya he didn’t mean too either. 😎😎
Tomas
Tomas
Message 43 of 46
shawn_miller
shawn_miller
Observer
Observer
What worked for me was setting the left and right scrolls to 'Do Nothing' and set the scroll wheel to 'Middle Button'. I actually like this better than the original settings, I don't accidentally pan left and right now. This problem kept the phrase "If it ain't broken don't fix it" running through my head. Logitec Mouse Issues.PNG
Message 44 of 46
Hi!
You can go to File, then Options menu, then go to 'SteeringWheels' and tick under the 'Look Tool Behavior'  the box that states, 'Invert vertical axis (Pull mouse back to look up).
You should be able to pan already the drawing.
Thanks.
Hi!
Thanks.
Tags (1)
Message 45 of 46
This worked! New computer and Revit 2019 didn't have a keyed shortcut entered for 'Pan Active Window'. As soon as I entered a shortcut the pan button worked! Was a silly and frustrating problem...
Tags (4)
Message 46 of 46
thanks, that help me to solve my problem
