What Things Cannot be Undone
7 ANTWORTEN 7
GELÖST
Nachricht 1 von 8
Ric_Weber
406 Aufrufe, 7 Antworten
I'm looking for a list of actions that cannot be undone.  For instance, we discovered that deleting a section cannot be undone no matter how much you try.  Is there a singular list out there somewhere that lists all actions that will not appear in the undo list of actions?
Thanks!
7 ANTWORTEN 7
Nachricht 2 von 8
als Antwort auf: Ric_Weber
Nachricht 3 von 8
Ric_Weber
als Antwort auf: barthbradley
@barthbradley my original question was if there is a list somewhere of everything that cannot be undone.  Actions that will not appear in the Undo list in order to be undone.  My example was that of accidentally deleting a section view and not being able to undo that action.
The link that you provided (thank you) states that this issue of not being able to undo deleting a view has been resolved...
Status:
This incident has been resolved in:
Revit 2018.2
We're in Revit 2022 and the undo of deleting a section view did not work.  Perhaps I need to put in a trouble ticket?
Nachricht 4 von 8
If a list exists, I'm not aware of it.
Save your Journal File and submit it with your Support Ticket.
Nachricht 5 von 8
mhiserZFHXS
What do you mean you can't undo deleting a section view? I'm doing it right now.
Nachricht 6 von 8
Ric_Weber
als Antwort auf: mhiserZFHXS
@mhiserZFHXS is your file workshared?  On BIM360 or ACC?  We are workshared on a network.  Not only does the undo of the section not work, but the entire list of actions to undo has disappeared.
Interesting tidbit for everyone.  If I just create a section and then delete it, I can undo that delete.  But if I delete a section that has been in the model for a while (how long, I don't know, haven't tested it that far yet).  Then the symptoms of loosing everything in the action undo list happens...  weird!
Thank you all.  I will be putting in a trouble ticket, because something appears to be going wrong.  This is happening on more than one system here in the office, so it's not just my system unfortunately.
Nachricht 7 von 8
Deleting a view, deletes the undo list???  Very weird.  Keep us posted.
Nachricht 8 von 8
Create section > Sync > Delete section > cannot be undone.
Sync > Create section > Delete section > can be undone.
