Message 1 of 17
06:51 AM
I want to make a 3D model of a bolt with its threads. My workflow to achieve this is:
- Create a generic model face based family (Family A) with the void I want to cut out of the bolt. This void consists of two swept blends between two profiles with the same geometry but different heights so that it creates a helix.
- Create Family B, also a generic model face based, which has an extrusion of a circumference.
- Nest family A into family B on the top of the extrusion to create the threads.
- Array family B to create as many threads as needed.
This is the concept. Now my problems:
- I can't seem to array family A throughout the bolt. Because of the way it's built, i can only array it in plan view, which is not what I need.
- Even if I copy family A in a front view to make further threads in the bolt, I can't cut the bolt with the copied void.
I wonder if the way to go would be to create an adaptive family? The problem is that I know nothing of adaptive families so I wouldn't know where to start.
I also tried a different approach. Instead of creating a void to cut the bolt with, I created the solid geometry consisting of the threads but this approach had its problems too.
How would you go about the problem?
PS: Can't figure out why the file size is so big!
