What's the best practice to model walls
Hello, I know this seems like a very basic question but here we go.
Recently I've been discussing about walls modelling. Lots of architects in my country/region tend to model walls as separate elements, from cores to finishes, everything as separate Wall elements, then glue everything joining the geometry to then make openings such as doors and windows. Schedules for walls are generally made using the Wall Type and not the materials used to make such types.
I tend not to like this method, because sometimes the geometry generated by separate walls usually seem sketchy and wall wraps (+ their representation through plans and sections) usually don't work with certain families of doors, windows and components, but I don't know if that's the only good way to model in order to get good schedules and good modelling geometry to have structure + walls + slabs all working.
So, how do you usually model walls? What's the best practice to have everything down in terms of geometry, schedules and other problems that can eventually happen? Is using a "hybrid" solution the best of both worlds?
