What's going on with the constraints?
lara.nazarian
lara.nazarian
Hello.
I have made several objects using the profile edit, but this time it shows this error.
kadmonkee
trial and error - remove the constraints and continue until error does not appear again.
the complexity of the shapes create overlaps in the design which could be causing the error to begin with.
try cutting in half .......fix it then mirror it
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
That's the Edited Profile of a Wall???  Wow, that's pretty ambitious - and optimistic.  I wouldn't expect it to work personally.  If you really want to model it - as opposed to maybe doing through a Material Image - I would model it in a Family and then load and place Instances of the Family in the Project.  But, keep in mind that all those intricate curves will most likely be indistinguishable once Thin Lines is turned off. Could look like big blobs at certain View Scales.  Maybe modeling a less intricate representation for Medium and Coarse View Detail Levels would be a good idea too.  Save this representation for Fine Detail Level only.
Just my two-cents worth.
