This gizmo suddenly appeared in my projects? It is so weird.And I can not even touch it. Anyone? How can I get rid of it.
It is almost random, at times there is no gizmo around. And now instead of one I have two.
Thank you for you attention.
Gelöst! Gehe zur Lösung
Gelöst von aRcHiTeCt.JM. Gehe zur Lösung
... hi @Anonymous
... yes , it is a well known issue with the 2020.2 update
... goto VG
... site
... and un-check the internal origin
… this thread has been around a lot since the update
… sometimes existing 2020 files are seeing the internal origin category being turned on in 2020.2
… sometimes upgraded projects from prior to 2020 versions are not affected
…. they don’t print… so no problem … just get use to those
… also take a look at this forum discussion / explanation
… changing-internal-origin-default
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
Why the hell did AutoDesk turn this GIZMO on. So now when I open an drawing that has not been opened since latest update I have to go to every single view and go to VG then Site and turn GIZMO off. If I don't and zoom extents in view, the view takes the gizmo in consideration and my view ends up being smaller. Then I have to manually zoom in. This is sooooooooo!!! irritating. Autodesk do you like to drive us mad!!! Have one setting that you can turn it off globally in drawing...
Now I get it why @ToanDN was impressed on YOUR OTHER POST HERE ...How did you manage to put all that together? prepackaged?
