What is the best way to tag the length of a travel path?
Gelöst! Gehe zur Lösung
Gelöst von ralphdenhaan. Gehe zur Lösung
You can just use the Tag by Category function.
https://help.autodesk.com/view/RVT/2022/ENU/?guid=GUID-F9943131-87F1-4D88-AC69-80BEB05E6A69
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
What version of Revit you work in? You can load a tag from the Autodesk Library for example. Or create a Custom Generic Tag family.
(You can change the Label afterward).
