What is the best way to create a 3D instruction manual from a revit file?
1 ANTWORT 1
Nachricht 1 von 2
mgwynnM8PSW
151 Aufrufe, 1 Antwort
Hi,  we have a detailed revit file of a simple structure down to the nail pattern and want to create a 3D instruction manual.  What is the best way to do that allowing  you an easy way to manage the sequencing?
1 ANTWORT 1
Nachricht 2 von 2
syman2000
als Antwort auf: mgwynnM8PSW
Crop your 3d detail using section box. Then save and lock the view
Then use displace elements
Then move the component to create your 3d instruction how to frame your building. Duplicate the same 3d view and you repeat the same displacement for the next instruction.
