What is the best way to add or manage materials in linked structure?
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
wickedzik
347 Aufrufe, 3 Antworten
Hey guys,
I am adding materials to my building in architecture which is easy for me, but i have a linked file from structure which don't have materials assigned on it, therefore it shows only Gray color.
The linked structure columns and beams are exposed and is visibly don't match with my wall materials.
What is the BEST WAY or ways to add materials to the linked exposed structure model/objects that will match with my archi wall materials?
I need your advice. Thanks in advance.
3 ANTWORTEN 3
Nachricht 2 von 4
cbcarch
als Antwort auf: wickedzik
If you have access to the Struct. model, open it in the same session of Revit and use Transfer Project Standards>Materials
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Nachricht 3 von 4
After transfer the materials, you will need to either change the materials for the structural elements, or Paint the exposed surfaces. if you do not own the file then the process will need be repeated when the engineer sends you a new file. So, in some cases, it may be easier to draw thin finishes in your file to cover the structural, then give them materials.
Nachricht 4 von 4
wickedzik
als Antwort auf: ToanDN
Thanks so much sir. I think i do covering.
