Hello Revit community, I need your help!
I would like to create a shading family that sprouts from the ground in a flower-like form. It would have a stem that supports the top, which is gonna be like a curved Lilly pad with different sizes. I would also like to able to control the heights of these elements through the use of reference lines and family parameters.
I have linked a few photos for reference, I need the family to look exactly like the shading in the pictures.
Revit offers a lot of different choices to do model families, what is the most efficient and functional way to start this task?
Gelöst! Gehe zur Lösung
Gelöst von syman2000. Gehe zur Lösung
Easiest way is create a form and then set it as planting so it will scale. See attached
Thank you so much for your fast and accurate input, this is exactly what I needed, you are amazing!
