What is "Callout Tag" Parameter in Elevation Views used for?
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
ZA_Sean
1076 Aufrufe, 6 Antworten
I'm cleaning up some of our Tags, and I notices a "Callout Tag" parameter in our Elevation Views. What's the use of that?
Our elevations tags are a simple arrow pointing toward the elevation and a detail/sheet.
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: ZA_Sean
You mean a parameter in the properties of elevation views? If so, tt could be introduced for filtering purposes.
Nachricht 3 von 7
ZA_Sean
als Antwort auf: ToanDN
In the "type Properties" of my Elevation Tags, there's a "callout Tag" parameter - in the Graphics category.Annotation 2019-02-18 123033.jpg
Nachricht 4 von 7
Okay so I misunderstood.  That Callout Tag is the definition for the Callout view type, including Callout head and Corner radius.  Callout head can be select from a Callout head family type loaded in your project, Corner radius can be typed in directly.  This is so you can have different Callout view types for different purposes, for instance: Plan callout versus Detail callout.
Nachricht 5 von 7
ZA_Sean
Right, I understand WHAT a Callout Tag is, but why is it in the Elevation View properties?
Nachricht 6 von 7
Nachricht 7 von 7
Because you can create an elevation view by draw a call-out on another elevation view.
