I am investigating how I can have walls pushing away the terrain. I know you could use building pads underneath each wall but what if the wall is made of a profile. What if there are multiple levels.
Are there other options to cut away toposurface?
As long as it remains a Toposurface, your options are limited to pads, grading and subregions. The poch representation displayed by Revit is not a solid form which can be cut in sense of cutting a geometry
Options are as follows using dynamo:
@RDAOU wrote:As long as it remains a Toposurface, your options are limited to pads, grading and subregions. The poch representation displayed by Revit is not a solid form which can be cut in sense of cutting a geometry
Something cool would be a dynamoscript that create pads based on what I select (walls, stairs etc) and places them underneath each selected item, based on the selected items' Min Z elevation
- convert it to a mass or generic component
- convert it to a floor element with modified sub-elements
- Convert it to a directshape cut by the wall geometry
When you wor
