Weld Symbol Family - Lines NOT lining Up
I need to change the text size of a weld family to a larger text which is 9/64". This is matching project standards. However, due to the larger text size, the weld family symbol is too small. You can see that it needs to be made wider so that it does not interfere with the weld symbol:
However, When I modify the family, when the symbol is pointing to the Right - I cannot get the leader to connect properly:
I cannot figure out what controls this connection and cannot get this GAP to go away.
Family is attached to this post. I need the labels to have a wider area so that they fit the larger text properly.
