As an attachments, I have issue of the stair is my stair runs from Level 1 to Level 2, but in the Floor Plan of Second Floor, it is still showed whole stair and overlapped the shaft opening, while on the Third Floor, it is only showed from beyond the shaft. Is there any solution for this?
Thank you!
are you talking about the visual style that you on wireframe? try changing it to hidden line
This could be caused by a number of settings. On the second floor view, is the floor element overridden in the view? Check the right-click menu of "Override Graphics in View > By Element" to see if any overrides are present. Are floor elements being overridden in the view in general? Check the Visibility/Graphics menu for the second floor view. As @Soroush.Bahrani mentioned above, is the visual style set to Wireframe rather than Hidden Lines? I would check all of these first, then let us know.
