Hi everyone!
So i've been having this problem with one file. It is a model of a tower with linked files for the both the structural and the facade components, as to make it easier to handle. However, when i create a camera view, some of the facade panels dissapear. I've double checked the properties of the panels families and their position (to make sure they are visible, as well as not duplicated or overlapping).
The first image attached shows the 3D view of the main model, and as you can see all of the components look neat. However, in the image below, which is taken from a Revit camera, you can see how a weird glitch happens to the view. I've also tried to adjust the height and position of the camera, but it only makes the glitch move along. Finally, i tried deleting those views and creating new ones, but the problem persists.
Has anyone had this issue? I can't figure out how to solve it and my coworkers and I have even had our computers checked, as to make sure it is not caused by the graphic cards or some other hardware malfunctioning.
Thx in advance!
Have you tried turning off Hardware acceleration to see if this corrects the problem?
Area Object Link |
Attribute Modifier |
Dwg Setup |
Feet-Inch Calculator
Layer Apps |
List on Steroids |
VP Zoom Scales |
Exchange App Store
Hi Pli!
Yes! In fact, we have turned Hardware Acceleration to the minimum since the very beginning of our modelling. So I had discarded that option.
