Weird curtain wall (roof) offset of the panels
david.akeretPBGD8
david.akeretPBGD8
Hello
I need to model a inclined roof and i like to use a curtain system for it. So i used the roof modelling tool an draw a line in a section view. I change the properties of the roof to curtain wall. What happens is that there is an offset of the roof to my modelled extrusion line as you can see here: (Red line is the extrusion line)
When i check properties: it says that it is 0.1m thick? Where does this come from?
When i check the glazing panels:
There is no offset and the glazing thickness is 0.002m
Here the curtain wall type properties:
So what am i missing? I just want that it creates the roof there where i place the extrusion line
Im happy if somebody can help.
regards david
Curtain Walls are composed of Mullions and Panels which have a specified thickness and depth and offset from the Center Line of  Curtain Wall. Does that help your understanding?
david.akeretPBGD8
Hi
so far i understand the concept. But where can i change that 😑 ?
When i draw a curtain wall with the wall tools. I can exactly set the offset of the panels. It seems that it doens not apply when i use the roof modelling tools.
regards david
