Weight Tag for generic model families
I've created a weight tag for generic model families by creating a new Volume parameter which I have to input. I would like to use the volume parameter that Revit produces automatically so every time the volume changes the weight tag is altered automatically without having to input the volume.
Please see image attached of weight tag and the the 2 volume parameters
Any help would be much appreciated.
XXalessio.amodioXX
Unfortunatelly this is not possible.
But easly solveble with a simple Dynamo script.
Create a project paramter e.g. XX_Volume (To distinguish from the revit one) .
Thank you for your reply.
I had tried to create a dynamo script before but it didn't work. I guess it was because both parameters had the same name. Just tried it and it works. Thank you for help!
