Question: Where can I find a list of the Autodesk Knowledge Network support solutions that were created and/or updated for Revit Architecture?
January 2016
Week 1:
Architectural walls appear in a structural plan view
Can’t connect to Revit Server Accelerator
Point clouds: Number of displayed points changes as you zoom, hover or select
Revit 2016 does not use language packs
Revit Server: Slow performance with hard disk encryption
Sketch lines disappear after finishing
Archive
December 2015
Week 1:
Beam and Column connection issue in Revit
Week 2:
Built in parameters in Electrical equipment family template
Collaboration for Revit Error: The current user doesn’t have the write access to the document…
Foundation slab area property is not exported to DWF/ DWFX format
IFC duct elements missing in Revit view
Revit 2016 R2: Unable to make changes in color scheme
Revit: Hang when printing to PDF with 2016 R2
The Select Views window is blank when gluing a model from Autodesk Revit
Week 3:
Assembled stair carriage and stringer support parameters are mixed up in Russian
Creating MSP out of EXE for Revit 2015 UR10
Exporting Revit families with SDNF-Export
Navisworks: How to use Switchback with a Collaboration for Revit model
Revit overwrites instance parameters when swapping families
Revit: How to find the Release 2 update for 2016 for Eflex customers
UK English Revit includes American terms for beams' Structural Usage property
Values for Top and Base are not displayed for balusters created in Revit in a different language
Week 4:
2016: How to Complete a Clean Install and Uninstall of Revit products
Auto-ceiling detects boundary of walls and structural columns but does not place ceiling
Extra linework printed from curved walls over 180 degrees in perspective views
Hidden line display for custom line style controlled through wall hidden line subcategory
Revit: Fill pattern is not printed
Revit: Lines Missing in DWG Export
Revit: Software emulation in use when in Citrix XEN App environment in Windows Server 2012
Vault Servers Revit Indexing Troubleshooting Checklist
