Weekly New Knowledge Articles by Support team | Sep 8th - 14th
Knowledge articles written by our Revit support team to resolve the problem on your own. There're couple of incidents reported, do take a look at them for possible workarounds.
Published Date |
Summary |
Knowledge Article |
Incident Reported |
10-Sep-21 |
A project parameter needs to be translated to represent another parameter in Revit. |
How to use a parameter to modify output of another parameter in Revit |
No |
13-Sep-21 |
Users reported that negative volumes might be reported by API calls (using Dynamo for instance) for some objects when importing (opening) IFC files in Revit. |
Negative volumes are reported for some floors for an IFC file imported into Revit. |
Yes |
13-Sep-21 |
Assertion failed: line xxx of ..." when opening the file in Revit. |
Assertion failed: line xxx of ..." when opening the file in Revit |
Yes |
09-Sep-21 |
After exporting NWC from Revit the upper face of a slab is not displayed in Navisworks. |
After exporting NWC from Revit the upper face of a slab is not displayed in Navisworks |
No |
09-Sep-21 |
"The linked file does not contain geolocation data." when acquiring coordinates in Revit |
No |
08-Sep-21 |
Users reported, that the Revit journal file contains lines with "API_Error : Assembly version conflicts". |
"API_Error : Assembly version conflicts" reported in the Revit journal file |
Yes |
10-Sep-21 |
Users reported that it is not possible to add tag or dimension to detailed group in Revit. |
Yes |
