Weekly New Knowledge Articles by Support team | Sep 28th -Oct 4th, 2022
0 ANTWORTEN 0
Nachricht 1 von 1
lim.wendy
125 Aufrufe, 0 Antworten
Knowledge articles written by our Revit support team to resolve the problem on your own. There're couple of incidents reported, do take a look at them for possible workarounds.
Published Date
Summary
Knowledge Article
Incident Logged
28-Sep-22
Block geometry from AutoCAD looks different than in AutoCAD after linking DWG file in Revit.
Block geometry from AutoCAD looks different after linking DWG file in Revit
No
28-Sep-22
How do you investigate the factors that influence synchronization speed outside of Revit?
No
28-Sep-22
Is it possible to exclude IFC-classes while linking IFC files in Revit?
Is it possible to exclude IFC-classes while linking IFC-files in Revit
No
28-Sep-22
When Installing Revit Server, the following error appears: Operating System Unsupported
Operating System Unsupported error when installing Revit Server
No
30-Sep-22
The ceiling grid pattern is not displayed in reflected ceiling plan, but does show up in plan view.
Ceiling grid not visible in Revit reflected ceiling plan view.
No
30-Sep-22
When cropping or uncropping a view, or when zooming in / out the view doesn't change.
Crop/Uncrop and Zoom in/out doesn't change view in Revit.
No
01-Oct-22
After acquiring coordinates in Revit, the True North rotation does not match the source file.
Acquired Coordinates do not match True North rotation in Revit
No
03-Oct-22
Users reported that demolished ducts join to new construction ducts in Revit.
Existing demolished Ducts and pipes join to New Construction Ducts/Pipes in Revit
Yes
03-Oct-22
Users reported that railings have not the same slope as stairs in Revit.
Railings have not the same slope as stairs in Revit
Yes
04-Oct-22
"An exception has occurred when opening the dialog" warning appears when numbering rebars in Revit.
No
04-Oct-22
Inserting a door in a thin wall is impossible in Revit.
Cannot insert a door in a thin wall in Revit
No
04-Oct-22
Model stuck while opening in Revit on Windows 11
No
04-Oct-22
Sections and elevations are removed from sheets when rotated in Revit
No
04-Oct-22
Type IfcGUID not exported to IFC from Revit
No
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
0 ANTWORTEN 0
