Weekly New Knowledge Articles by Support team | Nov 23rd - 29th, 2022
2 ANTWORTEN 2
Nachricht 1 von 3
lim.wendy
228 Aufrufe, 2 Antworten
Knowledge articles written by our Revit support team to resolve the problem on your own. There're couple of incidents reported, do take a look at them for possible workarounds.
Published Date
Summary
Knowledge Article
Incident Logged
29-Nov-22
Users reported that "Export Type to IFC As" and "Type IFC Predefined Type " parameters lost their connectivity to IFC Schema mapping after installing Revit 2023.1.1 update
"Export Type to IFC As" and "Type IFC Predefined Type " parameters lost their connectivity to IFC Sc...
No
29-Nov-22
Pipes are not created correctly when linking IFC file using specific template in Revit
After linking IFC file, pipes are not shown correctly using specific template in Revit
No
29-Nov-22
Users reported that using Fabric Area feature in a split wall in Revit creates duplicated fabrics.
Double layer fabric area in a split wall in Revit
Yes
29-Nov-22
Geometry of Fabrication pattern CID 533 breaks when editing the item in Revit
Yes
29-Nov-22
Users reported that IFC class assignment by 'Export to IFC As' parameter doesn't work for parts while exporting IFC from Revit.
IFC class assignment by 'Export to IFC As' parameter doesn't work for parts while exporting IFC from...
Yes
29-Nov-22
Users reported unexpected circular shadow in a realistic view after the upgrade of the model to Revit 2021 or a newer version.
Unexpected circular shadow in realistic view after upgrade of the model to Revit 2021 or newer versi...
Yes
28-Nov-22
Is it possible to create a multi-segment void that fits the family dimension in Revit?
How to create a multisegment void that fits the family dimension in Revit
No
25-Nov-22
Users reported that color number from exportlayers file does not influence material colors in IFC exported from Revit
Color number from exportlayers file does not influence material colors in IFC exported from Revit
No
25-Nov-22
Is it possible to add cost parameter for different types and diameters of pipes in Revit?
How to add cost parameter for different types and diameters of pipes in Revit
No
25-Nov-22
New coordinates for the model have been established. How to correctly adjust model position in Revit?
How to adjust model position in Revit after coordinates review
No
25-Nov-22
Is it possible to set the position of the analytical beam line to top in Analytical Automation in Revit 2023?
How to change the position of the analytical beam line in Analytical Automation in Revit 2023
No
25-Nov-22
How to export Room boundaries as polylines to DWG from Revit. When exporting the room boundaries to DWG only
Yes
25-Nov-22
Is it possible to read in tags the elevation of the MEP elements according to the internal origin in Revit?
How to read in tags the elevation of the MEP elements according to the internal origin in Revit
No
25-Nov-22
Users reported that IFC PROVISIONFORVOID element not showing in floor plan in Revit.
IFC Provision for Void element not showing in floor plan in Revit
Yes
24-Nov-22
Revit closes suddenly after launch in Windows 11
No
23-Nov-22
Users reported that local coordinate system of walls is inverted exporting model to Robot Structural Analysis from Revit.
Local coordinate system inverted exporting model to Robot Structural Analysis from Revit
Yes
23-Nov-22
Users reported that IFC.RVT model is wrongly rotated linking it to project with rotated True North in Revit.
Wrongly rotated IFC.RVT linking it to project with rotated True North in Revit
Yes
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
2 ANTWORTEN 2
Nachricht 2 von 3
Elie_Trad
als Antwort auf: lim.wendy
Users reported that "Export Type to IFC As" and "Type IFC Predefined Type " parameters lost their connectivity to IFC Schema mapping after installing Revit 2023.1.1 update issue is resolved after installing IFC for Revit 2023.2.3.0 plugin
Nachricht 3 von 3
Elie_Trad
The issue is back after installing Revit 2023.1.2, and it is not resolved when installing IFC for Revit 2023.3.3.0 plugin
