Weekly New Knowledge Articles by Support team | Nov 17th - 23rd
Knowledge articles written by our Revit support team to resolve the problem on your own. There're couple of incidents reported, do take a look at them for possible workarounds.
Published Date |
Summary |
Knowledge Article |
Incident Reported |
18-Nov-21 |
Users reported that specific geometry of walls and floors join will be inaccurate at IFC export from Revit. |
Incorrect geometry at IFC export of walls cut by floors from Revit |
Yes |
18-Nov-21 |
When rotating a crop view in a floor plan in Revit, the elevation tags become inverted |
Elevation tags become inverted when crop region is rotated in Revit |
Yes |
17-Nov-21 |
Users reported that model are exported with wrong Z coordinates to IFC with Shared Coordinates with IFC 22.3 from Revit 2022. |
Wrong Z coordinates exporting model to IFC with Shared Coordinates with IFC 22.3 from Revit 2022 |
Yes |
18-Nov-21 |
How to turn off worksets when opening workshared Revit models. |
No |
22-Nov-21 |
Incorrect graphic display while editing section box in Revit 3D view or moving elements. The edges will be multiplied until the command will be finished. When the edition mode is no longer active, only a single edge will be displayed. |
Incorrect edges display while editing elements in Revit 3D view |
No |
17-Nov-21 |
When opening a Revit model that contains Links that utilize Shared Coordinates for positioning, the Shared Site name is lost in the properties of the link. |
Linked models lose Shared Site name when the host model is opened in Revit |
No |
17-Nov-21 |
Users reported that an incorrect MEP fabrication transition part tag value is not correct in Revit. |
Offset tag SU/SD top parameter reporting incorrectly in Revit |
Yes |
18-Nov-21 |
Elements are not placed at the expected elevations when they are placed in floor plan in Revit |
Elements are not placed at the expected elevations when placed in floor plan in Revit |
No |
18-Nov-21 |
Users reported that certain IfcSpace parametersets and attributes inside them are getting exported to IFC2x3 as expected, but not when trying to export the same model to IFC4 format from Revit. |
IFC Space attributes missing after exporting models to IFC4 from Revit |
Yes |
18-Nov-21 |
Users reported that transferring View Templates via Project Standards unexpectedly copies the list of linked CAD Imports from the source file into the Visibility/Graphic Override Dialog of new project files. |
Yes |
22-Nov-21 |
Wires are moving on upgrading a model to Revit 2022 |
Yes |
22-Nov-21 |
Users reported that number display cannot be set after the following digit grouping format: 123 456.789 |
Yes |
22-Nov-21 |
User reported that geometry from Dynamo is not inserted in Family Types in Revit 2022. FamilyType.ByGeometry node is used. Empty Family Types are produced. Instances can be placed in model. |
Yes |
22-Nov-21 |
User reported that it is impossible to work with GIS Plugin when IFC model is imported in Revit 2022.1. IFC is not inserted properly. |
It is impossible to work with GIS Plugin when IFC model is imported in Revit 2022.1 |
No |
19-Nov-21 |
How to report roof footprint dimensions via Instance and Global Parameters in Revit? |
How to report roof footprint dimensions via Instance and Global Parameters in Revit |
No |
19-Nov-21 |
Keyboards shortcut alt key indicators stop working after a three level deep command is used in Revit. |
Yes |
