Weekly New Knowledge Articles by Support team | May 1st - 5th, 2023
0 ANTWORTEN 0
Nachricht 1 von 1
lim.wendy
101 Aufrufe, 0 Antworten
Our Revit support team has created knowledge articles for you to address the issue on your own. Several incidents have been reported, so be sure to review them for potential workarounds.
Published Date
Summary
Knowledge Article
Incident Logged
4-May-23
Ambient shadows (Sombras Ambientales) are not displayed for selected level and range in Revit
Ambient shadows are not displayed for selected level in Revit
Yes
4-May-23
Unable to select duct centerline when using align option in Revit.
Cannot select duct grid after using align option in Revit
No
4-May-23
How to adjust rebar set top with a sloping surface of a wall in Revit?
How to lay out rebars in a sloping wall in Revit
No
4-May-23
Only one pattern for the overlaps solids is displayed in Revit 2024, while in older versions multiple cut patterns would display at the same time.
Multiple cut patterns for overlapping solids don't display in Revit
Yes
4-May-23
Revit appears to have a section plane that obscures the model
No
4-May-23
View with NWD stutters/slows down in Revit even though the PC runs relatively easily.
No
4-May-23
"Revit encountered a serious error" appears randomly while working on a specific model in Revit LT and sometimes the model crashes with a CER.
"Revit encountered a serious error" while working on a specific model in Revit LT
Yes
4-May-23
Exporting a particular Revit model to DWG produces a corrupted file with incorrect curtain wall hatches and lines.
Exporting a particular Revit model to DWG produces a corrupted file with incorrect curtain wall hatc...
Yes
3-May-23
Invisible Repeating Detail Component in Revit 2024 and Revit LT 2024
Yes
2-May-23
Users reported that holes (voids / openings) are not exported to IFC from Revit
Holes not exported to IFC from Revit
Yes
2-May-23
When creating a schedule, it is still showing a header even after having it uncheck in the properties dialog in Revit.
Schedule Headers are still showing even after having it uncheck in the properties dialog in Revit
Yes
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
0 ANTWORTEN 0
