Our Revit support team has created knowledge articles for you to address the issue on your own. Several incidents have been reported, so be sure to review them for potential workarounds.
Published Date |
Summary |
Knowledge Article |
Incident Logged |
14-Mar-23 |
A space is not visible in floor plans but is visible in the schedule in Revit |
No |
13-Mar-23 |
"This field cannot be blank. Enter text to continue." message when trying to map parameters in families in Revit. |
No |
13-Mar-23 |
Users reported that Structural Framing position is incorrect after changing height type property in Revit. |
Structural framing behaves incorrectly when editing its height in Revit |
Yes |
11-Mar-23 |
Model is shown on screen and status bar says "Ready", however the "Open Model" dialog box shows no progress on bars and is unresponsive. |
No |
10-Mar-23 |
It is impossible to export IFC when "Building Story" level parameter is active in Revit. |
Cannot export IFC when "Building Story" level parameter is active in Revit |
No |
10-Mar-23 |
Keynote tags move after sync with central and re-opening in Revit |
Yes |
10-Mar-23 |
Users have reported that when using the 'Filter by Sheet' option on a Note Block Schedule, the view template for the schedule gets overridden. |
Note Block Schedule view template overridden when using 'Filter by Sheet' |
Yes |
10-Mar-23 |
Wrong distance between Fabrication items in Revit |
Unexpected distance value between Fabrication items in Revit |
No |
9-Mar-23 |
Users reported that they cannot map IfcPredefinedType for Structural Rebars (IfcReinforcingBar) when linking IFC in Revit. |
Cannot map IfcPredefinedType for Structural Rebars (IfcReinforcingBar) when linking IFC in Revit |
Yes |
9-Mar-23 |
Is it possible to modify the unit setting for levels in Revit? |
No |
9-Mar-23 |
How to view a model created in a previous Revit version without needing to upgrade it. |
How to view a model created in a previous Revit version without upgrading it |
No |
9-Mar-23 |
When creating a Model In-Place component, after selecting the category and clicking OK, the model disappears in Revit. |
Model disappears from view when using the Model In Place command in Revit |
No |
9-Mar-23 |
Users reported that when inserting components, not with the same sequence as the P&ID schema in Revit the following message appears:'Some of the connected objects no longer match their P&ID location[...]'. |
Yes |
9-Mar-23 |
When working with Revit Windows sporadically crashes with a Blue Screen on a specific machine. |
Sporadic Blue Screen crash of Windows when working with Revit |
No |
9-Mar-23 |
Texts in schedules (Schedule Graphics) are not exported correctly into DWG from Revit. |
Text in schedule is not exported correctly into DWG from Revit |
Yes |
9-Mar-23 |
Users reported that it is not possible to export insulation as IfcCoveringType with predefined type WRAPPING using IfcExportAs from Revit |
No |
8-Mar-23 |
"System.ArgumentException: An item with the same key has already been added..." when starting Dynamo in Revit |
No |
8-Mar-23 |
What is the possibility of loading and editing an IFC model in Revit? |
No |
8-Mar-23 |
When selecting walls in a particular Revit project, the graphic display is incorrect. The location line unexpectedly displays outside of the wall. |
No |
8-Mar-23 |
Placing Rebar on slopping floors does not work in Revit. |
Yes |
8-Mar-23 |
How to use Revit with Digital Twins? |
No |
8-Mar-23 |
Special characters do not export to PDF as expected in Revit |
Yes |
8-Mar-23 |
Where to find useful add-ins for Revit? |
No |
