Our Revit support team has created knowledge articles for you to address the issue on your own. Several incidents have been reported, so be sure to review them for potential workarounds.
Published Date |
Summary |
Knowledge Article |
Incident Logged |
7-Mar-23 |
When attempting to copy elements across between Revit projects, Paste Aligned to Current view doesn't paste elements in the expected location. |
Yes |
7-Mar-23 |
Cannot export to IFC mapped type parameters in Revit. |
Yes |
7-Mar-23 |
Revit Server 2023 admin panel does not work when other older versions do. |
No |
6-Mar-23 |
Accepting primary Design Option causes elements to disappear from main model in Revit |
Yes |
6-Mar-23 |
Users reported that it is not possible to create the same type of assembly for the identical pipeline contained in the Tap junction in Revit. |
Assembly does no longer recognizes same type with taps in Revit |
Yes |
6-Mar-23 |
There is no possibility for multiple users to edit the same design option at the same time (Worksharing) in Revit. |
Design option cannot be edited by multiple users at the same time in Revit |
Yes |
6-Mar-23 |
Editing of blocked, predefined view templates in Revit. |
No |
4-Mar-23 |
Crashes and slow opening and synchronizing of models on Revit Server. |
Crashes and slow opening and synchronizing of models on Revit Server |
Yes |
4-Mar-23 |
Spinning wheel when using the Tag Room button in Revit |
Yes |
3-Mar-23 |
Accepting Primary Design Option unexpectedly removes sheet in Revit |
Yes |
3-Mar-23 |
Users reported that imported IfcOpenings lose their references (hosts) during IFC export from Revit. |
Imported IfcOpenings lose their references (hosts) during IFC export from Revit |
Yes |
3-Mar-23 |
Lines from an inserted CAD file in a family cannot be removed in Revit |
Yes |
3-Mar-23 |
Users reported that properties of floor openings get lost at IFC export from Revit. |
Missing properties at exporting floor openings to IFC from Revit |
Yes |
3-Mar-23 |
Users have reported that when using Multi-leader keynote tags to tag multiple instances of the same family, using either the 'Show one leader' or 'Select leaders to show' option results in the tag showing "<varies>". Multi leader keynotes don't work as expected. |
Multi-Leader Keynote Tag Incorrectly Displays "varies" in Revit |
Yes |
3-Mar-23 |
The coordinates of the project base point are incorrect after transferring the project standards in Revit. |
No |
3-Mar-23 |
When trying to create a New Sheet in Revit the option is greyed out. |
Unable to create a New Sheet as the option is grayed out in Revit |
No |
3-Mar-23 |
Users reported that it is not possible to export wall to IFC as IfcWall using "Export to IFC as" from Revit. |
Unable to export wall to IFC as IfcWall using "Export to IFC as" from Revit |
Yes |
2-Mar-23 |
How to obtain information for Revit trainings? |
No |
2-Mar-23 |
Material not carried over when attaching Fabrication items in Revit |
Yes |
2-Mar-23 |
Unable to create path of travel lines around linked cad files in Revit |
Unable to create path of travel lines around linked DWG files in Revit |
No |
1-Mar-23 |
Cannot permanently remove macro from Revit project. The macro keeps coming back when the project is re-opened each time the micro is deleted. |
Yes |
1-Mar-23 |
Wall is not adjusted to a new window shape after demolishing an old window and placing a new one in Revit. |
The opening size created by a demolished window is not aligned to a new window in Revit |
No |
