Knowledge articles written by our Revit support team to resolve the problem on your own. There're couple of incidents reported, do take a look at them for possible workarounds.
Published Date |
Summary |
Title |
Knowledge Article |
Incident Logged |
01-Jun-22 |
Users reported that EQ constraint not working properly with linked models in Revit. |
EQ constraint not working properly with linked models in Revit |
Yes |
01-Jun-22 |
How to create a door family with a glass panel in Revit? |
How to create a door family with a glass panel in Revit |
No |
01-Jun-22 |
Is it possible to open Revit model restored from Revit Server locally? |
How to open locally Revit model restored from Revit Server |
No |
01-Jun-22 |
Users reported that rebar schedules are generated much slower in Revit 2023 than in Revit 2022. |
Rebar schedules generated much slower in Revit 2023 than in Revit 2022 |
Yes |
01-Jun-22 |
Stair Stringer Created in Advance Steel is reversed when imported into Revit |
Yes |
01-Jun-22 |
Yes |
01-Jun-22 |
Warning: String.Contains operation failed when running Dynamo for Revit script |
No |
03-Jun-22 |
After running System Analysis in Revit, a new report is generated and the following message appears: "EnergyPlus simulation did not generate a report for systems analysis". |
"EnergyPlus simulation did not generate a report for systems analysis" in the created Analysis Report after running System Analysis in Revit |
Yes |
03-Jun-22 |
Users reported that a custom family highlights unexpectedly when loaded into a project and hovering over an area outside of its extents in Revit. |
Custom family highlights unexpectedly when hovering over an area outside of its extents in Revit |
Yes |
03-Jun-22 |
Electrical elements copied to another floor via clipboard, this elements are not visible in the new floor in Revit. |
Electrical elements copied to another floor via the clipboard are not visible in Revit |
No |
03-Jun-22 |
Users reported that there are missing elements in IFC created from Rukon after importing into Revit. |
Missing elements in IFC created from Rukon after importing into Revit |
Yes |
04-Jun-22 |
After running a custom Python script in Dynamo that changes the transparency setting for all model categories in Revit, a crash occurs and the following error message appears: "A fatal error has occurred. The application will be terminated. You have the opportunity to save recovery files for all of your changed projects...". |
"A fatal error has occurred. The application will be terminated..." and Revit crashes after running a custom Python script in Dynamo and clicking the Filters tab in the Visibility/Graphics dialog box |
No |
06-Jun-22 |
Unable to map IFCFlowTerminal as Sprinkler using IFC mapping table when linking IFC in Revit. |
Cannot map IFCFlowTerminal as Sprinkler using IFC-mapping table when linking IFC in Revit |
No |
06-Jun-22 |
Cannot rotate elements using align function in Revit |
No |
06-Jun-22 |
User reported that manually moved rebar from rebar distribution is displayed on wrong side in section view in Revit. |
Manually moved rebar from rebar distribution displayed on wrong side in section view in Revit |
Yes |
06-Jun-22 |
Users reported that after upgrading models from Revit 2020 to 2022, the structural framing tags lose association with the beams (i.e. the tags should be parallel with the beams, as they were before). Instead, every single one is vertically up the page, regardless of beam plan rotation. The tags are referencing elements in a linked RVT model. It seems that this issue only applies to tags associated with beams. Other elements that are rotated in this way are walls for which the tags are rotated correctly. |
Structural framing tags added to linked elements (RVT Link) lost orientation after upgrading models to a higher Revit version |
Yes |
06-Jun-22 |
Unable to select automatically parameter values for all categories while creating Filter in Revit. For some categories values already entered in the project have to be placed manually in the filtering rule. |
Unable to select automatically parameter values for all Categories while creating Filter in Revit |
No |
07-Jun-22 |
When working with Coordination models linked into Revit, these models do not live update as other files do. |
Linked Coordination models do not live update in Revit |
No |
07-Jun-22 |
Users reported that the non-masking Solid Fill Region covers wall color in Revit 2023 plan view. |
Non-Masking Solid Fill Region covers wall color in Revit plan view |
Yes |
