Weekly New Knowledge Articles by Support team | July 27th - Aug 2nd, 2022
0 ANTWORTEN 0
Nachricht 1 von 1
lim.wendy
192 Aufrufe, 0 Antworten
Knowledge articles written by our Revit support team to resolve the problem on your own. There're couple of incidents reported, do take a look at them for possible workarounds.
Published Date
Summary
Knowledge Article
Incident Logged
30-Jul-22
Can you load your own families into Revit using the "Load Autodesk Family" tool?
No
30-Jul-22
When trying to split a schedule within a sheet in a Revit project, the “Split Schedule Table” Z break control is missing.
Split Schedule Table control missing for Schedule in Revit
No
29-Jul-22
Users reported that Arabic text is shifted when exporting sheets from Revit to AutoCAD.
Arabic text is shifted when exported from Revit to AutoCAD
Yes
29-Jul-22
Users reported that filled region or rebar patterns are not printed/exported to PDF from Revit.
Filled region or rebar patterns are not printed/exported to PDF from Revit
Yes
29-Jul-22
Is it possible to change the default path for local copies of Revit central models?
How to change the default path for local Revit models
No
29-Jul-22
How to cut a floor intersecting with a roof in Revit.
No
29-Jul-22
Steel connections types not visible in the dialog box or SQLDumperExe window opening and closing when creating steel elements in Revit.
Steel connections types not visible in the dialog box or SQLDumperExe window opening and closing in ...
No
29-Jul-22
The voids of the openings in beams are not exported to IFC from Revit.
Voids in beams are not exported to IFC from Revit
Yes
28-Jul-22
"There is no active document in Autodesk Revit" warning appears in Robot during exporting model to Revit.
"There is no active document in Autodesk Revit" when exporting model from Robot to Revit
No
27-Jul-22
When copying a group from one file to another the dwgs are duplicated in the 'Imported' category for Visibility Graphics but in "Manage Links" are listed only once in Revit.
Copying a group from one file to another results in duplicated DWGs in the 'Imported' category for V...
No
27-Jul-22
Yes
27-Jul-22
DWG text overlapping when linked into Revit
No
27-Jul-22
Users reported that hosted line loads applied to panels in Revit are not exported to Robot.
Hosted line loads applied to panels in Revit are not exported to Robot
Yes
27-Jul-22
How to make a reveal profile element visible and assign a material to it in Revit?
How to make a reveal profile element visible and assign material to it in Revit
No
27-Jul-22
Users reported that rebar shape 21 is not correctly displayed after setting "Hook Rotation At Start/End" to 90 degrees in Revit.
Rebar shape 21 is not correctly displayed after setting "Hook Rotation At Start/End" to 90 degrees i...
Yes
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
0 ANTWORTEN 0
