Weekly New Knowledge Articles by Support team | Jan 4 -10th, 2023
0 ANTWORTEN 0
Nachricht 1 von 1
lim.wendy
192 Aufrufe, 0 Antworten
Knowledge articles written by our Revit support team to resolve the problem on your own. There're couple of incidents reported, do take a look at them for possible workarounds.
Published Date
Summary
Knowledge Article
Incident Logged
10-Jan-23
Impact of adding, removing, copying, pasting elements on the file size of Revit
No
10-Jan-23
Users reported that Rectangle.ByWidthLength node does not work in Dynamo (version 2.16.1) for Revit 2023.
Rectangle.ByWidthLength node does not work in Dynamo for Revit
Yes
10-Jan-23
When attempting to export a view to an OBJ file from Revit, the option is greyed out.
The option to export to OBJ is greyed out in Revit
No
9-Jan-23
Users reported that the message "Cannot open the filename.IFC" is displayed while opening IFC from Archicad in Revit.
"Cannot open the filename.IFC" while opening IFC from Archicad in Revit
Yes
7-Jan-23
When working in a Revit model, you encounter the following error "Can't edit the element until [Username] resaves..."
"Can't edit the element until [Username] resaves..." when working in in Revit model
No
6-Jan-23
Users reported that moving sloped fabrication pipe led to misaligned hangers
Moving sloped fabrication pipe shifts hangers
Yes
6-Jan-23
New tags show as a question mark when tagging elements in Revit 2023
Yes
6-Jan-23
PCF file exported from Revit uses True North rotation and not Project North
Yes
5-Jan-23
How to export shared parameters to IFC from Revit?
No
5-Jan-23
Users reported that the part does not have the same shape as the original element in Revit.
Part is not reflecting original element in Revit
Yes
5-Jan-23
Unable to export IsExternal parameter to IFC using user defined property set file from Revit
No
4-Jan-23
Users reported that a dense model pattern assigned to the Ceiling category is missing in the PDF export from Revit.
Model pattern for Ceiling category is missing in PDF export from Revit
Yes
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
0 ANTWORTEN 0
