Knowledge articles written by our Revit support team to resolve the problem on your own. There're a number of incidents reported; do look at them for possible workarounds.
Published Date |
Summary |
Knowledge Article |
Incident Logged |
14-Feb-23 |
"Revit could not find or read X references. What do you want to do?" appears for a specific computer when opening a cloud project in Revit |
No |
14-Feb-23 |
When opening a Revit file, you encounter the following warning: Schema Conflict when Loading a File |
"Schema conflict when Loading a file" for Enigma or Traceit when opening a model in Revit |
No |
14-Feb-23 |
When linking IFC files into Revit, the following error is encountered: Cannot open <Filename>.ifc |
Cannot open <Filename>.ifc error encountered when linking IFCs into Revit |
No |
14-Feb-23 |
How to avoid editing elements on worksets owned by other users in worksharing Revit projects? |
How to avoid editing elements on worksets owned by other users in worksharing Revit projects |
No |
14-Feb-23 |
IES data embedded in a lighting fixture family via the API in Revit is lost when the family file is moved. |
Yes |
14-Feb-23 |
Initiating a particular model to Autodesk Docs fails at 50% in Revit |
Yes |
14-Feb-23 |
Users reported that after upgrading IFC Exporter to the version 22.6.0 for Revit 2022 user defined property sets and properties are not exported to IFC from Revit. |
Yes |
11-Feb-23 |
Dynamo is unresponsive after launching within Revit |
No |
10-Feb-23 |
The "File" tab takes about 20 seconds to open in Revit. |
No |
10-Feb-23 |
How to assign individual instances of the same family to different types of applications in Revit? |
Assigning individual instances of the same family to different types of applications in Revit |
No |
10-Feb-23 |
It is impossible to rotate project north in Revit. |
No |
10-Feb-23 |
How to install CivilConnection2023 for Dynamo? |
No |
10-Feb-23 |
The PDF file size is several times bigger when using the PDF export option instead of printing them from Revit. |
When exporting PDF, file size is significantly bigger than for printing PDF in Revit |
No |
10-Feb-23 |
When linking CAD file to Revit, checking "Current view only" checkbox grays out the "Orient to view" checkbox. |
When linking CAD file to Revit, checking "Current view only" grays out the "Orient to view" checkbox |
Yes |
09-Feb-23 |
Legend components and Fill Patterns are distorted when exported to PDF or DWF from Revit. |
Legend components and Fill Patterns are visible partly after exporting sheets to PDF or DWF in Revit |
No |
09-Feb-23 |
Changing the room name parameter takes a long time in one Revit model |
Slow performance when editing a room name parameter in Revit |
Yes |
09-Feb-23 |
Text appears wider when exporting the PDF compared with print to PDF and Revit display. |
Text appears wider when exporting the PDF compared with print to PDF and Revit display |
No |
09-Feb-23 |
Users reported that after opening a view or restarting Revit project browser and properties windows size is changing. |
Project browser and properties windows resize after opening a view or restarting Revit |
Yes |
08-Feb-23 |
Users reported that slanted walls are not exported to IFC from Revit. |
Yes |
