Our Revit support team has created knowledge articles for you to address the issue on your own. Several incidents have been reported, so be sure to review them for potential workarounds.
Published Date |
Summary |
Knowledge Article |
Incident Logged |
28-Feb-23 |
Crash when attempting to export ACIS (SAT) from Revit. |
Yes |
28-Feb-23 |
Users reported that exporting the same Revit model to IFC4 and to IFC2x3 format and comparing the results, the geometry at wall ends in the two files is slightly different. |
Different wall end geometry after IFC4 or IFC2x3 export from Revit |
Yes |
28-Feb-23 |
Error: You do Not Have Access Rights to.. When opening files in Revit. |
Error: You Do Not Have Access Rights to.... when opening files in Revit |
Yes |
28-Feb-23 |
Users reported incorrect position of IFC linked model in Revit. |
Yes |
28-Feb-23 |
Users reported that linked file is shifted exporting model to IFC from Revit |
Yes |
28-Feb-23 |
Revit crashes with a CER when clicking in the Change Service tool in a large set of MEP fabrication ductwork. |
Revit crashes with a CER when clicking in the Change Service tool |
Yes |
28-Feb-23 |
Different, unconnected duct or pipe systems in different building parts are registered as one single system in the System Browser in Revit. |
No |
28-Feb-23 |
Unable to use the "Get License" button for Autodesk Point Layout plugin |
Unable to use the "Get License" button for Autodesk Point Layout |
No |
27-Feb-23 |
Aligned patterns in a group are not applied to other placed groups in Revit. |
Aligned patterns in a group are not applied to other groups in Revit |
Yes |
27-Feb-23 |
A particular system is not listed in the Pressure Loss Report - System Selector dialog in Revit. |
System missing from the Pressure Loss Report - System Selector dialog in Revit |
No |
25-Feb-23 |
"Fix group" error is triggered for one particular user when trying to open a Cloud Worksharing file in Revit. |
No |
25-Feb-23 |
gbXML exported from Revit cannot be analyzed in Autodesk Green Building Studio and Run(s) failed message appears. |
gbXML exported from Revit cannot be analyzed in Autodesk Green Building Studio |
Yes |
24-Feb-23 |
Users reported that deleting couplers moves rebars in Revit. |
Yes |
24-Feb-23 |
Dynamo node FamilyType.ByGeometry cannot create family types in Revit. |
Dynamo node FamilyType.ByGeometry is unable to create family types in Revit |
No |
24-Feb-23 |
Users reported that beams with variable height are extended by 12.7mm (0.5 inches) when joining it with structural columns in Revit. |
Yes |
23-Feb-23 |
Spot elevations on a pipe in a pipes assembly become invisible when the model is closed and reopened in Revit. |
Spot elevations on pipe in assembly become invisible when model is closed and reopened in Revit |
Yes |
22-Feb-23 |
Lack of type choice when loading Revit family from Vault into Revit |
Lack of type choice when loading family from Vault into Revit |
No |
22-Feb-23 |
Users reported that top part of model is not imported while linking IFC to Revit. |
Yes |
