Weekly New Knowledge Articles by Support team | Feb 23rd - 1st Mar, 2022
0 ANTWORTEN 0
Nachricht 1 von 1
lim.wendy
163 Aufrufe, 0 Antworten
Knowledge articles written by our Revit support team to resolve the problem on your own. There're couple of incidents reported, do take a look at them for possible workarounds.
Published Date
Summary
Knowledge Article
Incident Reported
25-Feb-22
When viewing the Pipe Size in the properties of Revit, the Size is incorrect.
Pipe size is not correct in Revit
No
25-Feb-22
Users reported that Yes/no parameters are not working in lookup tables in Revit.
Yes
25-Feb-22
Users reported that parameter values with units get incorrectly exported when activating the Export Option "Export user defined parameter sets" and "Export parameter mapping table"
Incorrect export of unit defined parameter values in User defined parameter sets in Revit
Yes
26-Feb-22
“Group instances of the same type do not contain identical members" error when placing a room in a group in Revit
“Group instances of the same type do not contain identical members" error when placing a room in a g...
Yes
25-Feb-22
Elements in the IFC file are missing when IFC is opened in Revit 2020 and 2021
Yes
25-Feb-22
"To save the model to the cloud, you need access to Autodesk Docs" when try to save as cloud model in Revit.
"To save the model to the cloud, you need access to Autodesk Docs" when try to save as cloud model i...
No
23-Feb-22
Users reported that drop down windows appear transparent in Revit.
Drop down windows appear transparent in Revit
Yes
26-Feb-22
Is it possible to configure a local server with Windows Server operating system on which Revit would be installed? When users connect remotely to a server using Hyper-V, will a graphics card routed to the terminal using Discrete Device Assignment (DDA) be detected? It is critical that the Hardware Acceleration option be enabled in Revit.
Configuration of a local server with Windows Server operating system that can be used by multiple Re...
No
25-Feb-22
Users reported that “The duct/pipe has been modified to be in the opposite direction causing the connections to be invalid.” is displayed syncing model to central in Revit.
“The duct/pipe has been modified to be in the opposite direction causing the connections to be inval...
Yes
01-Mar-22
Custom Flow parameter for connector is greyed out for Mechanical Equipment when loaded into a Revit project.
Custom Flow parameter for Connector is grayed out in the Revit project
No
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
0 ANTWORTEN 0
