Weekly New Knowledge Articles by Support team |Dec 1st - 7th, 2021
0 ANTWORTEN 0
Nachricht 1 von 1
lim.wendy
192 Aufrufe, 0 Antworten
Knowledge articles written by our Revit support team to resolve the problem on your own. There're couple of incidents reported, do take a look at them for possible workarounds.
Published Date
Summary
Knowledge Article
Incident Reported
02-Dec-21
When exporting a Revit model which contains Fabrication content to DWG, the layer mapping is ignored.
When exporting Revit Fabrication content to DWG, the layer mapping is not followed
No
02-Dec-21
Revit hangs when changing material type on multiple instances of a Floor
Yes
04-Dec-21
Not able to import a draft view from a model to another in Revit
No
07-Dec-21
Users reported that top rails ends are not exported to IFC from Revit.
Top rails ends not exported to IFC from Revit
Yes
07-Dec-21
Unable to access Revit Server Administrator panel from a mainstream web browser after installing Revit Server 202X.1. The following warning appears: "Server Error in '/RevitServerAdmin202X' Application...Runtime Error...".
"Server Error in '/RevitServerAdmin202X' Application...Runtime Error..." when trying to browse Revit...
No
01-Dec-21
Global parameters assigned to a project/type parameter for a loadable family get disassociated on duplicating the family type.
Global parameters assigned to a loadable family parameter gets disassociated on duplicating the fami...
Yes
07-Dec-21
Can I create a Revit 2022 Deployment with different Content Packs?
No
07-Dec-21
When working in Revit and looking at the naming for local files, the local file has an appended timestamp at the end
Some local Revit models have an appended timestamp
No
07-Dec-21
Users reported that when turning on the Draw MEP Hidden Lines option in Revit that DWG geometry shows through elements which should be covering them when printing.
DWG shows through geometry when using Draw MEP Hidden Lines option when printing in Revit
Yes
01-Dec-21
Significant increase in the size of NWC file exported from Revit 2022 compared to export from previous Revit version.
Significant increase in size of NWC file exported  from Revit 2022 compared to export from previous ...
No
03-Dec-21
When exporting IFC file from Revit with the option 'split walls, columns, ducts by level' while exporting IFC, ducts are exported as single objects, are not split by the levels.
Ducts not split with the option 'split walls, columns, ducts by level' while exporting IFC from Revi...
No
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
0 ANTWORTEN 0
