Weekly New Knowledge Articles by Support team | Aug 24 - 30th, 2022
0 ANTWORTEN 0
Nachricht 1 von 1
lim.wendy
133 Aufrufe, 0 Antworten
Knowledge articles written by our Revit support team to resolve the problem on your own. There're couple of incidents reported, do take a look at them for possible workarounds.
Published Date
Summary
Knowledge Article
Incident Logged
30-Aug-22
"Failed to import Formit file" when importing Formit file into Revit 2022
No
30-Aug-22
The location of the origin in a DWG is determined by a legend rather than a model view when a sheet is exported in Revit.
Location of the origin in an exported DWG is determined by a legend rather than a model view in Revi...
Yes
30-Aug-22
Users reported that room tags do not always place at the correct orientation in Revit.
Room tag orientation is not correct in Revit
Yes
30-Aug-22
Where to find out details about the revit.exe file data transfer between components
No
29-Aug-22
When editing the boundaries of the materials created with the split face option, it gives an error, and if an element is deleted, all the materials disappear in Revit.
Edit boundaries of split face makes all materials disappear in Revit
Yes
29-Aug-22
Is it possible to modify default bar members releases while runing Analytical Automation for model in Revit 2023
Is it possible to modify default bar members releases while runing Analytical Automation for model i...
No
29-Aug-22
What is the impact of bar member Structural Usage definition on analytical model in Revit
What is the impact of bar member Structural Usage type definition on analytical model in Revit
No
29-Aug-22
How to create a Data Exchange for a published 3D view so that contractors can open that view in Revit? Is it possible to create a workflow between teams based on this feature?
How to make changes in Revit to a published 3D view with a created Data Exchange in Autodesk Docs
No
27-Aug-22
Fabrication Part is incorrect when trying to place into Revit
Yes
26-Aug-22
What is the recommended workflow between AVEVA PDMS and Revit? How export data from AVAVE PDMS to continue further work in Revit?
Export data from AVAVE PDMS to continue later work in Revit
No
26-Aug-22
Users have reported that when applying some view Filters, Revit will crash with the message "Revit encountered a serious error".
Revit encountered a serious error when applying a view filter
Yes
26-Aug-22
Unable to create a new space tag annotation by the feature Tag by Category in Revit.
Unable to create space tag in Revit
No
25-Aug-22
Users reported that all linked elements are overridden while using Filter for Worksets with the 'contains' rule in the host model with links in Revit.
All linked elements overridden while using Filter for Worksets with the 'contains' rule in the host ...
Yes
25-Aug-22
It's impossible to remove any of the vertical grid lines in a curtain wall with fixed vertical grid lines and no horizontal grid lines in Revit.
Cannot remove vertical curtain wall grid lines in Revit
Yes
25-Aug-22
Connecting two cables to one monitor, font width reduced by 50% when printing to PDF from Revit
Yes
25-Aug-22
Detail Number is missing in Properties for some views in Revit.
No
25-Aug-22
Users reported that when exporting a DWG from Revit, the room boundaries polylines have precision differences causing perimeter and area calculation to be incorrect.
Room boundaries polylines are missing or unclosed in DWG exported from Revit
Yes
25-Aug-22
Certain ceiling patterns in upwards-facing underlays are missing when floor plans are exported to DWG in Revit.
Some ceiling patterns in underlays are missing when floor plans are exported to DWG in Revit
Yes
24-Aug-22
"A serious error has occurred" and workset checkout prompt when changing Boolean parameter in Revit
Yes
24-Aug-22
Text overlapping for PDF Export compared to Print to PDF for particular texts in Revit
Yes
24-Aug-22
Windows Defender ATP alerts about active malware of type Trojan:Win32\/Vigorf.A in Revit 2023
Windows Defender ATP alerts about active malware in Revit 2023
No
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
0 ANTWORTEN 0
