Weekly New Knowledge Articles by Support team | Aug 18th - 24th
0 ANTWORTEN 0
Nachricht 1 von 1
lim.wendy
236 Aufrufe, 0 Antworten
Knowledge articles written by our Revit support team to resolve the problem on your own. There're couple of incidents reported, do take a look at them for possible workarounds.
Published Date
Summary
Knowledge Article
Incident Reported
21-Aug-21
When internet becomes disconnected Revit crashes with a Customer Error Report. An add-in is causing the conflict. Disable it to clear the issue.
No
18-Aug-21
When running a graph in Dynamo for Revit, some nodes show an "Unresolved" error message and the run does not complete.
Some nodes show "Unresolved" status when a graph is run in Dynamo for Revit
No
20-Aug-21
Loads do not update in the panel schedule after changing the loads in Revit for Electrical equipment.
No
20-Aug-21
"Parts were not pasted" when trying to combine models with fabrication parts in Revit
"Parts were not pasted" when trying to combine models in Revit
No
19-Aug-21
When trying to link a topography from Civil 3D in Revit, the DWG uploaded to the BIM360 site does not appear.
Uploaded DWG to BIM360 does not appear when trying to link topography in Revit
No
19-Aug-21
Users reported that when navigating or zooming in/out of different views in a specific model, Revit hangs.
Revit hangs when navigating or Zooming in different views for a specific model
Yes
19-Aug-21
Fabrication button image displays incorrectly in Properties Palette in Revit
Yes
18-Aug-21
Columns are not visible in plan view but are visible in the 3D view in Revit.
Yes
21-Aug-21
"Data corruption in file an unnamed file" when moving an element in Revit.  "Data in file (file name).rvt is corrupt and needs to be manually recovered" when open with audit. The file is corrupt. Use a backup.
No
19-Aug-21
CPU usage spikes to 100% while the GPU usage only running 33% in average while rendering in Revit
Yes
23-Aug-21
When aligning walls in Revit, the geometry of the wall does not change.
Unable to align walls in Revit
No
24-Aug-21
When extending/shortening a structure beam with connection, hidden lines does not appear as expected.
Hidden lines for structural framing does not appear as expected in Revit
Yes
20-Aug-21
When opening any model in Revit, it takes longer than expected. When working later and using any commands there is also a noticeable drop in performance. This only applies to a specific computer. In addition, other software also behaves more slowly than on other machines in the same location.
Slow opening of models in Revit and further work on them due to not full use of CPU resources
No
20-Aug-21
Material Tags in Design Options are Question Marks until View Activated and Synced in Revit
Yes
21-Aug-21
Cannot create structural elements with Dynamo that have 'Structural' and 'Enable Analytical Model' options added and enabled in Revit. When an element such as Structural Floor is created manually in Revit, it has these options.
'Structural' and 'Enable Analytical Model' options missing when creating structural elements with Dy...
No
21-Aug-21
From where and how to install the eTransmit add-in for Revit 2017 version?
How to install the eTransmit add-in for Revit 2017 version
No
22-Aug-21
After installing Revit on Windows Server OS, the program does not start and throws an error. Looking at the reliability and problem history monitor (Control Panel > All Control Panel Items > Security and Maintenance > Reliability Monitor) on this computer there is a Critical Event for Revit.exe.
No
23-Aug-21
Users reported that when opening specific section view in particular Revit model then "IdMapColourBuffer.png" image is created in root folder. In most cases, contains outlines of elements on a black background that are visible in this open section view in Revit. For example, if a project is located in the N:\Projects\Project Name\... then IdMapColourBuffer.png image will be created in the root folder on N:\ mapped drive.
"IdMapColourBuffer.png" created in root folder when opening specific section view in particular Revi...
Yes
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
0 ANTWORTEN 0
