Knowledge articles written by our Revit support team to resolve the problem on your own. There're couple of incidents reported, do take a look at them for possible workarounds.
Published Date |
Summary |
Knowledge Article |
Incident Logged |
17-Aug-22 |
Customer has created a Floor Tag Family with the parameter 'Elevation at Top Core' and inserted it in project and reported that the family is not any corresponding returning the value. |
No |
17-Aug-22 |
What are the differences in exporting gbXML files when comparing Revit 2023 and 2022? |
gbXML file export differences when comparing Revit 2023 and 2022 |
No |
17-Aug-22 |
How to export Revit host model with linked IFCs into one IFC file ? |
How to export Revit host model with linked IFCs into one IFC file |
No |
17-Aug-22 |
After creating a Room Annotation Tag and adding multiple parameters to the label, some of them are not displayed in the Revit project. |
Some parameters are not displayed in Room Annotation Tag in Revit |
No |
17-Aug-22 |
When a structural column is cut in an elevation view, the column is not shown as cut, while architectural columns and other elements are cut in the elevation view in Revit. |
The cut pattern from structural columns is not visible in the elevation views in Revit |
Yes |
17-Aug-22 |
Underlay walls are shown in PDF exported using default PDF exporter in Revit |
Yes |
17-Aug-22 |
Material texture on the rounded edge is displayed in a different direction in Revit |
Material on the rounded edge is displayed in a different direction in Revit |
No |
18-Aug-22 |
When installing Geberit plug-in it is not displayed in Revit 2023. |
No |
19-Aug-22 |
45° Wye Tap fitting not converted as expected when using Design to Fabrication in Revit |
No |
19-Aug-22 |
What is the difference in the built of window families that some are not recognized by energy analyses in Revit? |
No |
22-Aug-22 |
Spaces are removed when Phases are merged in Revit |
No |
22-Aug-22 |
In structural columns the cut pattern is not visible if columns are shorter than 1219mm in Revit |
Structural column cut pattern is not visible if columns are shorter than 1219mm in Revit |
Yes |
22-Aug-22 |
Users reported that shared parameters cannot be displayed under fields for Structural Truss Schedule in Revit. |
Unable to display shared parameters under fields in Structural Truss Schedule in Revit |
Yes |
23-Aug-22 |
How to assign the default path for libraries in Revit to content from a previous version? |
How to assign default path for libraries to content from a previous Revit version |
No |
23-Aug-22 |
Users reported that when making changes in a Revit 2023 model in the realistic 3D view, the model turns different colors. |
Modifying elements in Revit results in color changes in 3D realistic view |
Yes |
23-Aug-22 |
The voids and the property set of the openings in slabs and walls are not exported to IFC from Revit. |
Yes |
23-Aug-22 |
A user running various versions of Revit sees a different number of available BIM 360/ACC cloud projects from the Home page. For example, there are 8 projects available in Revit 2021 and 6 projects in Revit 2023. |
Difference in number of available cloud projects from Home page in different Revit versions |
No |
Why are these only posted in the Architecture forum and not shared in the MEP and Structural forums?
Thanks for the suggestion @iainsavage
They will be posted in the Revit MEP and Structural forum next week.
