We are seeing a performance issue with opening revit files, in win10 vs win7
4 ANTWORTEN 4
Nachricht 1 von 5
it
320 Aufrufe, 4 Antworten
I have spent the last few days testing.
Two identical machines with same hardware has been tested, only difference is the operating system Windows 7 and Windows 10 1903
The Windows 7 system takes about 45 seconds opening our revit project from the central file
The Windows 10 system takes 200 seconds opening our revit project from central file.
I installed Windows 7 on the machine that had Windows 10 installed for the intial test and retested, the machine in order to exclude hardware faults, the retested machine took 45 seconds like the other windows 7 machine to open the project.
The two identical machines have the following specs:
Intel Core i7-5820K CPU @ 3.30GHz
ASUS X99-A Motherboard
16 GB KINGSTON DDR4 RAM 2133 mhz
500 GB Samsung 850 EVO SSD
Nvidia 960GTX
Have you seen any similiar behaviour ? What would you advice us to do?
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: it
Compare the spare free space on the C drive of both computers.  It may just be that Windows 10 is leaving you less free space.
Nachricht 3 von 5
martijn_pater
als Antwort auf: it
...wait 155 seconds :zwinkerndes_Gesicht: j/k
Nachricht 4 von 5
it
als Antwort auf: Anonymous
there are no space issues, they are clean installed test machines with plenty of space.
Nachricht 5 von 5
als Antwort auf: it
Windows 10 consumes much more resources than its predecessors so you may want to add more RAM to Windows 10 machines.
