I want to make irregular stairs, so please let me know. I can't think of any other way to do it. please help
Use Create Sketch option, defining the boundaries, risers and stair path
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
Autodesk Certified Professional
You can also first model the stair and then convert it to a sketch based.
I don't know what you mean by "irregular stair", but Component Stairs can manipulated using their Shape Handles. Is this what you are trying to do?
For that kind of gallery seating/stair I'd be inclined to use Model in-place and create the extrusions in section and then extend them as far as they would go in plan. You could also use a stair the left lower run and another stair for the left upper run. Then use Floors for the other seating and "floors/landings" required. The stairs and floors will not "join" up nicely and look monolithic so that's why I'd be inclined to go with "in-place" modelling. That would allow all the elements to look as if it was built "together".
Edit: I think you could accomplish it with the stair tool using sketch mode and multiple runs with different riser counts and height offset. Might be "easier" in-place though.
Steve Stafford
