We have a parameter set up to sort our sheets into different groupings such as DD, Permit and Misc. I believe in order to set up a new group I need to select 'Sheets' in the project browser and then edit folders in the properties menu, but the 'edit' button is greyed out. Am I on the right track and if so how do I add a new category to our sheet list?
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
No. Select the sheets from Browser and enter the value into the properties parameter that being used to group the sheets. It may be named Folder, or something else. To check: select a DD sheet and see where the DD is entered then use the same field.
This reply is completely incomprehensible. Adding a new sheet group should be so easy- it is difficult to imagine how it is not an intuitive, simple process.
This will answer the question, if you haven't figured it out yet.
https://www.youtube.com/watch?v=cE0fiQ_p-oM
IF THE PARAMETER IS ALREADY SET UP. GO INTO THE SHEET THAT YOU WANT TO PUT INTO A NEW TAB/FOLDER/DISCIPLINE, AND TYPE IN WHAT YOU WANT THE NAME OF THAT FOLDER TO BE INTO THE DISCIPLINE/SHEET FOLDER PARAMETER. IT WILL AUTOMATICALLY CREATE A NEW PARENT TAB IN THE BROWSER.
