Walls
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
farhansam618
454 Aufrufe, 6 Antworten
Walls
Dear Friends,
My walls are showing transparent in all views I am using the same wall type categories used in the model but only in the highlighted location it's transparent can anyone help me with this issue(i already checked the materials and VG settings)
Beschriftungen (1)
6 ANTWORTEN 6
Nachricht 2 von 7
syman2000
als Antwort auf: farhansam618
Can you post what wall material you have? If you have transparency material as one of the layer, it will show up as invisible in 3d.
Nachricht 3 von 7
I'll bet $1 that if you use UnJoin or Uncut on that wall, it will reappear.
Nachricht 4 von 7
_Vijay
Try to change the with view template... check the wall wether it's overrided or not..may be it's overrided.
Nachricht 5 von 7
farhansam618
als Antwort auf: syman2000
i used the same materials from the walls used in the model but only in that location its not showing
Nachricht 6 von 7
martijn_pater
Maybe try to recreate the view.
Nachricht 7 von 7
I guess I lost that bet. Can I Venmo you the $1.00?  :zwinkerndes_Gesicht:
