WALLS
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
1007 Aufrufe, 6 Antworten
WALLS
I have made double brick walls and a songle brick wall intersects with them. Unfortunately whatis seen at he intersection is not correct ? The single brick should NOT surpass through the first layer and get attahced to te second layer of the double brick wall? what can I do?
THIS IS WHAT I SHOULD SEE
6 ANTWORTEN 6
Nachricht 2 von 7
RDAOU
als Antwort auf: Anonymous
When you allow join...material of similar properties take precidence and join together. Example: similar finishes of intersectiong walls join together, structural elements of the intersecting walls join togetherYou need to look into your wall type properties
More info on wall joins HERE
Nachricht 3 von 7
chrisplyler
I'm guessing that your double layer brick wall has a structural definition that includes one layer of brick within the "core" and the other layer of brick outide of the core. Then your single layer brick wall is probably defined with the brick as the core. So it's trying to join to the "core" of the double layered wall.
Try building the double layered wall with both brick layers and the air gap all within the core.
Nachricht 4 von 7
RDAOU
Just re-arrange the order of the layer from inside to outside (Structural Core should be on the inside face or in simpler logic the bottom row of the list)
Wall Type Dialog
TOP --> Exterior Side
MID --> Core - Structural
BOTTOM --> Interior Side
If you put them all in the CORE the order should follow the same pattern Outside Layer on top; Inside Layer Bottom
Nachricht 5 von 7
als Antwort auf: chrisplyler
I give Kudos for the help but it wasnt the real solution to my POV. I have attached th emost rectent file
Nachricht 6 von 7
the question arises as to what does core boundary really mean.
Nachricht 7 von 7
RDAOU
@Anonymous
you've been on this forum for quite some time now and you've been using revit for a year maybe more during which you advanced a lot one can see from your models...but sometimes I personally have the feeling that you went through either quickly with less practice & experimenting or you skipped...namely topics such as walls which in the help files alone Autodesk has defined really thoroughly.
example...on the core and core properties as well as layer priorities see link below
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/Revit-Model/files/GUID-CCDEE011-2A5E-43AC-BD60-8F81CF432A6B-htm.html
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2015/ENU/Revit-Model/files/GUID-1CCD1005-CBDA-4338-8D60-489095D4BB25-htm.html
more ther on the topic but those explain more than enough to get u to master walls.
