Walls will not join properly
2 ANTWORTEN 2
Nachricht 1 von 3
STaylorDEEGK
294 Aufrufe, 2 Antworten
I currently am having an issue where two walls at a corner do not want to join. When attempting to join the two together, I receive the error "Can't keep elements joined." I also receive the error "Highlighted walls overlap. One of them may be ignored when Revit finds room boundaries. Use cut geometry to embed wall into another."  I have tried changing out different walls and disallowing join at each vertex. I have never used cut geometry but videos do not explain how it would help my situation
I am working in Revit 2022.
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: STaylorDEEGK
Try using the Wall Join tool and let us know if that works.
TIP: Activate Wall Join Tool, hover over one corner and press TAB key to select all corners. Then look at the options you have available on the Options Bar.  Try Miter and  Allow Join.
...BTW: we aren't talking about Stacked Walls or Walls with Base Offsets here; are we?
Nachricht 3 von 3
Do you have any existing wall being demolished at that corner?  Perhaps show a 3D view so that we can see the what's going on at top and bottom of the intersection.
