So if I set a work plain, somehow it got that way before I opened the brand new untouched project. so how do you re-set the presets before starting a new project? I didn't think you could until you are in the new project. Since using Revit four years ago, I would just open a new project and everything was good to go, not so with 2019. So there must be presets, although I find it odd that it would be preset to do it wrong. Also. I know the work plain is wrong, I have to reset it every single time I go to work in a different level, why does it switch back on its own?
I don't understand the question? Are you maybe wanting a different Template setup? Create one.
