Walls, Stair, other objects. Using Revit 2019
1 ANTWORT 1
Nachricht 1 von 2
135 Aufrufe, 1 Antwort
Started a new project, set and name levels; Placing walls, stairs and other objects; they are immediately drawing out a level below, why would this happen in a new drawing.  Floors go in right, but everything else drops down a level.  Why would this happen in a new project.  I have to fix everything in the Properties every time I use it.  its a pain.  Is there a solution?  Screen shots won't help, you will see nothing wrong.  you have to witness me drawing it.
1 ANTWORT 1
Nachricht 2 von 2
piotr.bocian
als Antwort auf: Anonymous
You probably set work plane to that level. Just check work plane: http://help.autodesk.com/view/RVT/2019/ENU/?guid=GUID-3426ADE0-6B76-4453-87EF-653DAE6BCBEC
