Walls not visible in floor plan
10 ANTWORTEN 10
GELÖST
Nachricht 1 von 11
n10263349
968 Aufrufe, 10 Antworten
Hi All, been working on a problem for too long.
Some of my walls are visible in Elevation & 3D but not visible in floor plan. I can make a new wall no problem.
Been through all the usual settings even checked same setting are used on visible wall for invisible.
Must be some setting some where as the wall is there, can anyone suggest a fix
10 ANTWORTEN 10
Nachricht 2 von 11
awes
als Antwort auf: n10263349
Have you tried Coordination Discipline in case you use both Arch and Structural walls.
Nachricht 3 von 11
TripleM-Dev.net
To less info to make a calculated guess.
But look into, worksets (on/off in view), Phasing used?, ViewFilters, Cutheight/bottom, Hidden In view etc....
Compare Elevation view settings to floorplan settings
Nachricht 4 von 11
What am I looking for in this screenshot? I'm seeing a red arrow pointing to what looks like a dimensioned wall opening.  Are you indicating that a low wall is supposed to be there?  If so, I would suspect View Range.  Maybe you need a Plan Region there?
Help | About Plan Regions | Autodesk
Nachricht 5 von 11
n10263349
Hi All, the floor plan snipit I sent shows the wall not visible, it's there as you can see (in snipit attached) its visible in elevation just not in floor plan. The settings are the same for all walls so this cannot be it. It is not hidden got me stumped!
Nachricht 6 von 11
just post the file.
Nachricht 7 von 11
Hit the reply button and you will see this screen.  See "Attachments" on it?
Nachricht 8 von 11
n10263349
Thank you see attached
Nachricht 9 von 11
n10263349
some walls on First floor West Elevation also same problem
Nachricht 10 von 11
For some reason, it doesn't like your View Depth of 100.  Drop it to 0 and Wall appears.
Nachricht 11 von 11
n10263349
als Antwort auf: barthbradley
Thank you so much, won't make that mistake again!!!
