Walls not showing in plam when I draw them in?
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
svalen
297 Aufrufe, 2 Antworten
I think my visibility settings and wall setting are correct. Also on in visibility graphics.
2 ANTWORTEN 2
Nachricht 2 von 3
kjskoog
als Antwort auf: svalen
In your View Range change the Top to Associated Level (Attic). Offset 7'-6"
Change your Cut Plane Offset to 4'-0".
Looks like your cut plane is at the same level as your base.
Kory Skoog
BIM Manager
Kory Skoog
PM/BIM Manager
Nachricht 3 von 3
Your view range is not correct. Add a number to Cut Plane.
1" would even work.
Right now, the Cut Plane is sitting at the base of the wall -- NOT CUTTING THE WALL.
