Walls not joining properly with wall base extension
12 REPLIES 12
Message 1 of 13
1892 Views, 12 Replies
I have not been able to get walls to join properly at corners when I use a wall base extension for two unlocked layers (the siding and plywood sheathing of a 2x6 exterior wall) to bring them down past the wall base so they can lap and cover 6 inches of the foundation wall, for instance. I have tried various join methods, butt, miter, and I have also tried this with the layers locked and extending the entire wall down to 6 inches into the top of the foundation wall below and then joining the two so that the wall gets cut and the siding runs past however this also leaves a “gap” at the corner joints. Anybody else run into a similar situation? Is this a Revit glitch or am I doing something wrong?
12 REPLIES 12
Message 2 of 13
ennujozlagam
post some screenshot or share part of your file so we can check. thanks
Message 3 of 13
in reply to: ennujozlagam
Thank you for the quick reply. Please see screenshots illustrating the issue.
Message 4 of 13
ennujozlagam
i don't see any screenshot or copy and paste your wall problem into a new file and post it here so we can check. thanks
Message 5 of 13
I replied to the email but I guess the attached images didn't come through. I am now attaching directly to the post on the forum.
Thank you
GS
Message 6 of 13
ennujozlagam
have you try to disallow and allow again join of two walls? thanks
have you try the wrapping setting?
Message 7 of 13
bin
Are they on same level with same base constraint?
Message 8 of 13
in reply to: bin
Yes they share the same base and top constraints. Can you duplicate the issue on your end or are you getting different results?
Message 9 of 13
bin
I’m pretty it will work without the base wall, maybe do something to the base walls, I’ll have a test after o get out of my bed.
Message 10 of 13
bin
in reply to: bin
I had a test and it worked. Maybe upload that corner part.
Message 11 of 13
No issues here.  Annotation 2019-10-10 161522.pngAnnotation 2019-10-10 161540.png
Message 12 of 13
I have noted before that sometimes pulling the walls apart and then trimming them back sorts out the problem.
Message 13 of 13
So I tried the configuration again from a new project, ground-up, this time using a different sequence of constructing the model: walls first, then roof, then foundation plan, then first and second floor plates, and the wall joins seem to work but ONLY if I use the Join>Miter command instead of Butt or Square Off, which I can live with. Also, it makes a difference if the walls that join at the corner are at the same base constraint; for instance, if one wall is constrained on a foundation wall that has a plate elevation that is higher (or lower) than the plate elevation of the adjoining wall, then even the miter command does not always work for me, unless I manipulate some variables.
Thank you for your input.
Forma Design Contest
